Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: main VE table
    Apr 2009
    Default main VE table
    okay iam new to this forum, ive done a lot of reading just never posted.
    i have a 2007 NNBS gms sierra 6.0 L
    i want to make a new VE table and get started on really dialing in my tune. i have a wideband o2 sensor already installed but i cant seem to find my main VE table {B0101}
    under my "airflow" tab its a red folder
    attached is my tune as of now
    if someone can help me out that will be appriciated
    EDIT: just realized i posted this in the wrong section.... someone please move it to either the gen IV or E38 section, whichever it belongs in
    thanks
    Oct 2006
    Check out this thread http://forum.efilive.com/showthread.php?t=8961
    It should set you on the right path.
    BTW welcome to the forum.
    ps The red folders mean you can only view/edit these tables while flashcan is connected.
    The Tremor at AIR
    Apr 2009
    Quote Originally Posted by 5.7ute View Post
    thank you
    ill try and mess around with this tutorial and see what happens
    this is what ive been looking for for a long time haha
    thanks again
    dillon
    Aug 2008
    Welcome to the EFI Live Forum....
    Glad to have another truck guy with a 6.0ltr V-MAX
    Post up your stock tune and I'll help you-out
    Also what Octane fuel are you using?
    FLASHSCAN V2 & AUTOCAL
    Apr 2009
    Quote Originally Posted by GAMEOVER View Post
    iam using 91, i based the tune off of the edge evo level 4
    attached is stock tune
    Aug 2008
    Have you made any tweaks to your Transmission?
    Apr 2009
    Ya I've removed all TM, bumped pressure in the line up, engadged my tcc in second gear, reduced shift times, I can't remember what else iam not by my lap top iam on my phone in class haha
    I can post it up when I get home if you guys want to critique it
    Apr 2009
    okay i fallowed everything step by step untill page 7 where i had to go to
    B8101
    i searched it and it came up i dont have it
    can someone help me out??
    thanks
    Oct 2006
    Do you have flashcan connected to the computer? If not you need to be to access this table.
    If you use search with a higher number table open it will not search backwards & will just go to the end of the list. Hit search again & it should show up. Unfortunately I dont have my flashcan here at work so I cannot check your tunefile for myself.
    The Tremor at AIR
    Apr 2009
    I had it connected and searched again when it went to the bottom of the list
    I don't know why it didn't show it doesn't make sence for me not to have it
    And I tried connecting my wb02 but it cantfind it.. Are auto meter wb02's compatable?
  1. Question in regards to the main VE table...
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: November 3rd, 2009, 12:11 PM
  2. Main and Boost VE...one table?
    By hquick in forum Custom Operating Systems
    Last Post: February 20th, 2008, 06:10 PM
  3. Main VE Table Question
    By dbaxter_ss in forum General (Petrol, Gas, Ethanol)
    Last Post: February 23rd, 2005, 12:38 PM
  4. Use of Main VE Table
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2005, 02:05 PM
  5. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 02:36 PM
