I am working on a 98 Firebird LS1 with auto trans. I have my VE table dialed in, and am working on the MAF table since the BENs are different with it plugged in vs SD mode. After I get it dialed in, what fuel trims do I want to shoot for. Currently I am running about 11.5 AFR at WOT. Is this too rich? I was thinking something along the lines of 12.5 or 12.8. What do you guys think? Is there a chart somewhere that I can use to determine the best AFR?
Also, where do I go to change the desired AFR above 4k rpm?
I also noticed that this car runs about 17-18 afr during cold startup, but seems to run OK. Is this possible? I have disconnected the air pump relay and still get the same thing. Will it even run OK at that AFR or do I have another problem? If it can run, then what do I need to adjust?
