Results 1 to 7 of 7
Thread: can't download my tune, could it be locked?
    Mar 2007
    Default can't download my tune, could it be locked?
    Hi all, this is my first post. I searched and read the how-to's but didn't find anything that was of any help for my problem.
    I have an ls6 w/ a custom OS tuned by a reputable tuner here on the east coast. I just purchased commercial v2 flashscan so I can tweak my settings. so far I've got everything hooked up, the scan program connects to the car no problem but I cannot download my tune.
    when I go to the 'flash' tab at the top of the screen in the tune program the option to 'read PCM calibrations' is greyed out. is my tune locked or am I doing something wrong?
    thanks
    always,
    welcome to the forum...
    You mean the PCM Read and PCM Flash buttons are greyed out...?
    Did you but the Scan&Tune or the Scan Only option...?
    If you got the Scan&Tune, then it sounds like your got the wrong license.
    Mar 2007
    thanks for the quick response joecar.
    I've got the scan and tune version, do you know how I would go about checking the license is correct?
    Jul 2004
    With the tune tool open, go to help/V2 VIN Licensing and see how many licenses are available. if it's 2, you have a Scan and tune, if it's 0, you have a scan only. If you have a Scan only, look in the box for a piece of paper with an upgrade or email me your serial number and I'll see if I have it on file.
    ira at fishtuning dot com
    Ira
    Mar 2007
    I do have the scan tune version, there are two licenses available on that screen.
    sending you an email now ira...
    Jul 2004
    It should work. When it left here it was already a tune, very occasionally Scans escape.
    If the cable is plugged into the computer when you start the tune tool, those buttons should not be grayed out.
    Ira
    Mar 2007
    I rebooted my cpu then opened the tuning tool and it connected. not sure why that fixed it but I'm just glad it worked.
    thanks for the help!
  1. Download Tune Settings
    By Coker6303 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 31st, 2008, 08:19 AM
  2. Tune locked, can't read?
    By eboggs_jkvl in forum FlashScan V2
    Last Post: January 31st, 2007, 04:52 AM
  3. Replies: 1
    Last Post: January 11th, 2007, 11:49 AM
  4. Anybody Have A Tune I Can Download???
    By YANKGTO in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2006, 07:34 AM
  5. Download v6?
    By IllusionalTA in forum EFILive V6
    Last Post: February 24th, 2006, 11:45 AM
