Results 1 to 10 of 12
Thread: how to tune allison tcm with efi
    Aug 2008
    Default how to tune allison tcm with efi
    under my calibration window where the alison calibration should be it says not used how do i use this feature?
    Oct 2004
    Most of the calibration sections should show "Not used", but there should be one or two which relate to the transmission (the others are powertrain related and are N/A for the Allison). It's the sane if you opened a LLY calibration, the transmissions items should shot "Not used".
    If this is not the case please send the calibration file to support@efilive.com.
    Andrew
    EFILive Crew
    Aug 2008
    i still cant find the calibration file for the allison
    Senior Member camcojb's Avatar
    Dec 2007
    Quote Originally Posted by kingboydmax View Post
    see the highlighted transmission section on the left? Click that and you'll get the trans tuning parameters. Click on the thumbnail below twice to see it fullsize.
    Jody
    07.5 4X CC 2500HD, EFI Live, MBRP exhaust
    new updated website!
    May 2009
    mines not there either????
    Dec 2007
    you guys hooked up to the tcm (not the ecm) and read and saved the tune, right??!!
    Jody
    May 2009
    sorry, but very new to the game... I've copied my factory tune, but do I need to go back to the truck and do it over and choose tcm?
    Dec 2007
    Quote Originally Posted by Tarkstoys View Post
    yes. Hook up to the truck, open the tune tool, hit the green arrow up top to read calibration info, and when the box pops up make sure you pick the tcm for whatever truck you have (LMM, LBZ, etc.) It will read your tcm tune, you can then save it and make changes and change things in the tune as you wish.
    Jody
    May 2009
    Thx, for the quick response! Do you have a retainer fee!LOL
    Jan 2016
    Quote Originally Posted by camcojb View Post
    Jody
    New EFILive user question ref TCM. Do I need to read the ECM and TCM contents separately with two requests to keep the saved files separate or can both be checked and read in one process request but still be saved separately? TIA for the addition info.
    Ray
  1. Allison DVT's
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: October 17th, 2009, 03:36 PM
  2. pulling tune "allison"
    By drdiesel in forum Allison 5 & 6 Speed
    Last Post: May 24th, 2009, 04:13 AM
  3. 06+ Allison DVT
    Last Post: August 10th, 2008, 09:09 AM
  4. LBZ/Allison Race Tune
    By 07nastymax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 1st, 2008, 02:41 PM
  5. How to tune / protect Allison
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 14th, 2007, 03:39 AM
