Results 1 to 5 of 5
Thread: Logging STFT
    Aug 2006
    Default Logging STFT
    I am running COS3 OLSD and want to try Semi OLSD. I have been told that STFT are much more accurate than a W/B O2 for near idle/idle conditions. I have selected the B0101 STFT map but, it is not active because I apparantly don't have the correct PIDs selected. I have done a search and see a lot of Semi OLSD info but, nothing on logging STFT. What PIDs need to be selected to make this map active?
    Thanks, Jeff
    Aug 2006
    I figured it out.
    Jeff, what was it...?
    Aug 2006
    Stupidity on my part. I overlooked the STFT PID.
    Jeff
    Ah, no worries then, I was starting to look into missing pids...
  1. stft (your input)
    By drdarthinvader in forum Custom Operating Systems
    Last Post: April 23rd, 2010, 10:49 PM
  2. STFT Idle
    By Mort in forum Custom Operating Systems
    Last Post: October 17th, 2009, 02:46 AM
  3. stft problem
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: June 29th, 2009, 12:22 AM
  4. Looking for STFT & other pids
    By Chalky in forum FlashScan V2 BB Logging
    Last Post: May 21st, 2008, 10:21 AM
  5. stft
    By 69camaro5speed in forum Custom Operating Systems
    Last Post: April 8th, 2008, 02:39 PM
