Results 1 to 5 of 5
Thread: 98 pcm reporting "not ready" at emission testing.
    Feb 2006
    Default 98 pcm reporting "not ready" at emission testing.
    Does anyone know what this might be. I have tried changing some of the conditions for dtc and it makes no difference. When I click on system readiness it gives me a not ready for catalyst, O2 sensor, evap, and air pump. The same as the emission station readout. Could I have a ground problem?
    Mar 2007
    heavily modified or stock?
    Feb 2006
    Stock except for long tubes and exhaust. Did not have this problem last year. There were some dtc set which I cleared and got it passed. Could running open loop cause this...like a general default? Thanks.
    Nov 2006
    LC-1 WBO2
    Feb 2006
    Thanks Mr. Prick. Will give it a try. Car has had marginal battery.
  1. Emissions Question "Not Ready"
    Last Post: July 31st, 2010, 12:20 PM
  2. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 01:48 AM
  3. Emissions Question "Not Ready"
    Last Post: July 5th, 2007, 07:21 AM
  4. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 11:53 AM
