Results 1 to 5 of 5
Thread: Need help licensing my PCM
    Apr 2009
    Default Need help licensing my PCM
    OK... I bought EFI live V2 used and it still has one license left. Well, I want to flash this tune my buddy sent me for my car and it's saying I need to license this PCM. Maybe I am just a big freaking idiot, but I have tried the "help" tab and I can't figure out how to use this last license for this PCM. Can anyone help me.... I am using the V7.5 software. I've looked all over the place how to do it and I just can't figure it out. Any help would be awesome!Thanks so much
    Update: Where the heck is the [License PCM] button????
    Nov 2006
    When you flash the PCM it will use the license.
    LC-1 WBO2
    Apr 2009
    Do I need to do a flash pcm calabrations or a full reflash?
    Nov 2006
    Either or.
    You will get a warning telling you you will be licensing Flashscan to the PCM.
    LC-1 WBO2
    When it says you need to license the PCM, just click OK or whatever the button says and then try flashing again.
    do cal-only flash if the file you want to flash is the same OS as what you already have in your PCM.
    do full flash if you're changing OS.
  1. Licensing
    By kistlerjm9 in forum Gen III V8 Specific
    Last Post: August 5th, 2009, 11:13 AM
  2. Licensing?
    By Mort in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2009, 02:06 AM
  3. Licensing
    By Biggsy in forum FlashScan V2
    Last Post: February 6th, 2007, 01:14 AM
