Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 84
Thread: EFILive Version 8 (Black Box Logging) is now available
  1. #21
    Oct 2006
    Pretty snazzy , good job .
    2006 Trailblazer
  2. #22
    Oct 2005
    When saving settings F6 stuff to the V2 unit I get a "Error: $010A Recieved data message contained unknown command action"
    This was after setting serial IO
    2014 VF SV LS3 Maloo.
  3. #23
    Oct 2006
    Did you go to the Windows task bar lower right and click V2 icon and update firmware ?
    Got same error until I did that .
    2006 Trailblazer
  4. #24
    Is this going to replace V7.5 completely soon ?
    Yes it will replace V7 completely. The standalone read/flash option is due next, followed by the V8 Scan and Tune PC based software.
  5. #25
    Paul, is there a way to set the non-custom precision...?
    No. The idea was that if you wanted the default units with a custom precision you'd set up the custom PID with everything the same except the precision.
  6. #26
    Quote Originally Posted by ringram View Post
    When saving the settings to FlashScan, there needed to be some way to tell FlashScan that the settings had been changed and to re-read the Settings.dat file. I had to add a new command to the FlashScan firmware to do that. Older firmware won't recognize that command and will give you the error you see.
    As Chevy366 said, upgrade the firmware to the latest V2.06.08 available in the latest V8 dowbnload on our downloads page.
  7. #27
    Oct 2006
    Noticed that with new build that just plugging in V2 does not trigger recognition of device , you have to physically select device in FlashScan and AutoCal Device Settings (lower right corner of window AutoCal or FlashScan)to get task bar tray icon of V2 for firmware updates .
    2006 Trailblazer
  8. #28
    When setting up custom units and you click the clear button, it exits back to the main BBL window. Shouldnt it just clear the values and keep the custom units pane open? Does it regardless if there are values in the min/max fields or not.
    Another question, any way to make it so when you put a PID in the Selected PIDs area in S&T BBL to have them disappear from Available PIDs? Right now when you add the same PID again it just moves where the PID was in the list, but I think having it disappear completely from the Available PIDs is a good idea.
    Third round here, whew! When you add a new controller selection, go to add the PIDs you wish to scan with, save the Options.txt file to your PC, and then click Program it appears everything works properly. However if you are using a different controller that you have not copied the *.pmm file to V2 already it will NOT program the new *.pmm file that isnt on V2 without first closing and restarting S&T BBL. (ie I made a dummy LS1 99-08 PID selection and programmed it but the LS1 99-09 .pmm file was not copied over.) Doesnt matter if I select Program All PMM Files (slower) or not, doesnt copy the new .pmm's till the program is relaunched.
  9. #29
    There is a fault with the V2.06.08 firmware, please read the "Known Issues" here:
    http://www.efilive.com/index.php?opt...tes&Itemid=134
  10. #30
    Nov 2006
    The auto update will not download Build 53,
    I'm stuck on Build 52.
    LC-1 WBO2
  1. EFILIVE V8 Black Box Logging Questions - Imperial units?
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: May 13th, 2009, 01:21 PM
  2. V2 Black Box Logging
    By Blacky in forum FlashScan V2
    Last Post: November 4th, 2007, 10:51 PM
  3. V2 black box logging?
    By articSS in forum FlashScan V2
    Last Post: September 23rd, 2007, 04:57 AM
  4. is black box logging available on v2 yet ?
    By imtduncan in forum General (Petrol, Gas, Ethanol)
    Last Post: August 18th, 2007, 12:11 PM
  5. Black Box Logging Bug ?
    By Ninety8C5 in forum General
    Last Post: July 24th, 2006, 02:31 PM
