Results 1 to 2 of 2
Thread: 8.1.2 Build 52 EFI HAPI Error
    Jul 2007
    Default 8.1.2 Build 52 EFI HAPI Error
    I've only been able to do this once.
    I started EFILive Explorer and then started Scan&Tune while explorer was starting up still. I then killed EFILive Explorer and worked in Scan&Tune. When I went to load a configuration, I got an error saying that the HAPI was unavailable and I could not access the V2.
    Starting up EFILive explorer returned access to the V2 for both Explorer and S&T. Repeated attempts to replicate the error have failed so far so it may be a timing / race condition. It may not be a big issue but probably worth noting.
    Simon.
    Apr 2009
    maybe the share a similar file libary (dll file) and when you killed the explorer that dll file was still a memory resident (hasn't been given a command to shutdown as of yet) ?
    that all i can think what "could" possibly cause it
  1. Replies: 8
    Last Post: June 11th, 2010, 11:21 AM
  2. error $0025 hapi won't start
    By acomp917 in forum FlashScan V2 BB Logging
    Last Post: February 7th, 2010, 02:03 PM
  3. build 100 DSP 5 error
    By bballer182 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 22nd, 2009, 04:31 PM
