Hi,
Ross and Blacky I have emailed you both in the past about a COS for the e38 OS 12619078 which allows the use of nitrous activation via the ethanol tables.
I am running Vortech T trim...9psi boost and I want to run a 50 nos shot into the intercooler for extra benefits at the drag strip to prevent heat soak at the staging lanes, etc.
I have the option of a hobbs pressure switch but I really need to be able to compensate for the fueling via the pcm as it will be a dry shot.
