Results 1 to 10 of 10
Thread: setup info ??
    Mar 2009
    Default setup info ??
    is there a v2 file floating around that is all setup? i tried to setup the v2 with this http://forum.efilive.com/showthread.php?t=10714 and tried to log but a no go? what all do i need to setup to make this thing work almost ready to run it over. i need help bad i am lost big time my eyes hurt from reading and reading
    04 gmc cc 4x4 6ltr tuned by w4me
    operator error
    efi-live v2 sitting on shelf
    i am to dumb to operate
    Nov 2006
    You BB and FW are good?
    Have you configured the internal settings through the V2?
    There is a new version of the V8 software with FW but it is beta.
    You will not be able to go back to the old FW.
    LC-1 WBO2
    Mar 2009
    it came with 2.06.02 /2.06.06 i never flashed it.not sure on the internal setup
    operator error
    Jul 2007
    Quote Originally Posted by 2004gmc View Post
    Use the new V8 software. It works really well and it downloads the current options and *.pmm requirements making BBL much more fun and easy to use.
    I'm not sure of the programmer's exact instructs, but this is what I found while setting up and using it.
    1. Download the software and update the FS firmware to 2.6.07.efw
    2. Using the window's task mgr, delete all EFI live jobs that are running.
    3. Delete the current options and *.pmm files from flashscan.
    4. Run the new software, update go to F6 device settings, set and save that info and download to FS.
    5. Go to F3 black box logging and setup your pid's, download to FS.
    6. Download both OPTIONS and PMM files.
    This method of downloading the options file is far superior to the old method.
    From this point forward, it would take only a few seconds to edit and download a new options file.
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
    Mar 2009
    where is 2607 file? i dont see it
    operator error
    Nov 2006
    The installer places it in C:\Program Files\EFILive\V8\Firmware folder.
    LC-1 WBO2
    Mar 2009
    Quote Originally Posted by mr.prick View Post
    i dont have it? wheres the link to it?
    operator error
    Nov 2006
    LC-1 WBO2
    Mar 2009
    thanx mr prick got it now to try figure it out
    operator error
    Mar 2009
    thanx that worked it logged on its own
    operator error
  1. RR Setup
    By Harrismarine in forum RoadRunner Real-Time PCM Emulator
    Last Post: May 12th, 2009, 02:25 AM
  2. LC1 setup for e85 ?
    By yellowC6ohio in forum General (Petrol, Gas, Ethanol)
    Last Post: June 13th, 2008, 03:11 AM
  3. Need Help with E-fan setup....
    By MrZ71man in forum General (Petrol, Gas, Ethanol)
    Last Post: October 21st, 2007, 08:17 AM
  4. Don't want a war, but need some info
    By serpa4 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 18th, 2007, 12:17 PM
  5. Pic of my setup.
    Last Post: September 13th, 2005, 08:45 AM
