Results 1 to 10 of 10
Thread: 4l80e segment swap!!!
    May 2009
    Default 4l80e segment swap!!!
    Im looking for a tuning file to do a segment swap to a 4l80E from my 4l60E on my silverado. either for a customs os 01250003 or original os 12202088 THANKS!!!!!
    hyderm87, welcome to the forum...
    Some info:
    If you could copy all your tables to a 12212156 file, it would be easier to do (and you could use COS5).
    May 2009
    what do you mean? the os number you gave me matches for a 2002 os how would i swap to a different base os??? Thanks
    Junior Member 64camino's Avatar
    Oct 2007
    Basically you just need to find a vehicle that has a 4l80 in it, with the same os as yours, and copy the trans segment and paste it into yours.
    05 Silverado rcsb. forged 6.0,KBRacing front mount, TC-76, tuned with efi live.
    May 2009
    yeah that is the problem im having is finding a os like mine with a 80 in it. so far no luck!!!!!
    Oct 2007
    did you try holden crazy?
    Oct 2007
    never mind
    You can change OS by doing a full flash (after copying all the tables over).
    FlashScan V2 can do this.
    FlashScan V1 Commercial can do this... if you have V1 and it's not Commercial, then it's a $50 upgrade.
    You may not easily find any files containing 12202088/4L80E.
    It is easier to find files containing 12212156/4L80E.
    Follow the links in post #2.
    May 2009
    Thanks. i will try and let you know how it works out
    May 2009
    thanks for all the help it worked!!!!!!
  1. How do you do a segment swap?
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 8th, 2012, 07:18 AM
  2. need help with segment swap on 0411 ecm
    By stroker97k1500 in forum Vortec V6/V8 Specific
    Last Post: May 22nd, 2010, 10:42 AM
  3. 4l80e segment swap!!!
    By hyderm87 in forum Custom Operating Systems
    Last Post: May 12th, 2009, 02:29 AM
  4. A4 to M6 segment swap help
    By Aloicious in forum General (Petrol, Gas, Ethanol)
    Last Post: March 23rd, 2009, 09:24 AM
  5. Segment swap...Q's???
    Last Post: November 6th, 2007, 06:14 PM
