Results 1 to 7 of 7
Thread: Converting EOPS
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    Default Converting EOPS
    I just tried to convert Engine Oil Pressure from Volts to PSI and the drop down box only lists "None". as a conversion. I changed 'Factor' (32.0000) and 'Offset' (-16.00), but can't put 'psi' in the 'Quick Select' box.
    For Example, the 'Quick Select' box for temperature has 'F' or 'C'.
    Looks like I fixed it by adding the conversion to the 'EFILive.ini' file.
    Just checking, is this for the oil pressure voltage PID or just oil pressure?
    Sep 2003
    This is to convert voltage to psi for the Engine Oil Pressure Voltage (EOPS) PID.
    Ah I see, havent messed with said PID so didnt know if it was like some of the other ones where there are 2 PIDs, one that is strictly voltage and the other returns values in units (like kPa or PSI).
    Sep 2003
    Andrew,
    Do you think you can refer this to product development, so it doesn't get lost. Someone besides me must be using this PID.
    In Folder 'C:\Documents and Settings\All Users\Application Data\EFILive\V8', I added this line:
    "0110=V psi 0 32.00000 -16.0000 N"
    to file 'EFILive.ini'.
    Thanks!
    Adding the V->psi conversion for the oil pressure PID is tricky for two reasons:
    1. The V-psi entry you added will be available to all PIDs with units of Volts, but will not accurately apply to all the other voltage PIDs.
    2. More importantly, the voltage to psi scaling for the engine oil pressure is different for different controllers.
    Sep 2003
    I figured there might be some reason for it not to be added, but had no idea what it might be. Not a problem anymore.
    Thanks.
    I just checked my PID list and as long as I don't click on 'Quick select' and select 'psi' it doesn't affect my other PIDs that use 'Voltage' as their output. So I guess the conversion is okay for my usage?
  1. Converting tunes to DSP
    By rjwesleyiii in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 24th, 2010, 04:45 PM
  2. Converting to drive by cable.
    By Jon in forum Gen III V8 Specific
    Last Post: March 25th, 2010, 05:02 AM
  3. Converting serial Lambda to AFR
    By mr.prick in forum FlashScan V2
    Last Post: December 31st, 2009, 03:06 PM
  4. Converting Volts to AFR
    By Big Kahuna in forum General (Petrol, Gas, Ethanol)
    Last Post: December 16th, 2006, 01:44 PM
  5. Converting from HPTuner
    By Rod in forum General (Petrol, Gas, Ethanol)
    Last Post: June 15th, 2006, 10:18 AM
