Results 1 to 7 of 7
Thread: P0601 "Control Module Read Only Memory (ROM)"
    Apr 2007
    Default P0601 "Control Module Read Only Memory (ROM)"
    Hello and thanks for the help so far! I have the RR working but I have this P0601 hard code that keeps the check engine light on. I know how to get rid of it, but I wanted to know if this is a quirk with the RR ECM or if there is a problem with the ECM I have.
    Thanks!
    Mark
    "Never Enough" 2003 Chevy 2500 LT, CC-SB, TTS pistons, rods, cam, Diesel Performance Research heads, ATS trans, turbo, twin CP3 kit, Rick’s headers, Labonte water meth, FASS, SoCal balancer, ...
    Mark, it sort of rings a bell as a common issue with the RR ECM in the Duramax, but honestly I don't remember. Is it causing any problems apart from the annoying MIL?
    Apr 2007
    Not that I can tell. I will change it to not reported and see how it goes.
    I have a feeling it's because it cannot save any learn data back to the flash memory on shutdown as a normal ECM would, but as the Road Runner does not have real flash memory it will never be able to do it, hence the DTC sets.
    Dec 2005
    I have had my RR for over 3 years.
    That code is always present, no matter what.
    Just shut the MIL down and ignore it.
    www.mscservices.net
    Apr 2007
    Thank you.
    Ya thankyou also
    2017 Trailblazer 2.5L Dmax
    07 LBZ rc lb EFI - Sold
    05 lly cc lb, EFI 80hp tune-Sold
    01 lb7 rc lb EFI & Road Runner,1000+hp -Sold
    Duramax power
  1. P2563 code "Turbocharger Boost Control Position Sensor Performance"
    By Truckin Stuff in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 3rd, 2009, 01:11 PM
  2. Reducing "agression" of cruise control on hills?
    By endo in forum General (Petrol, Gas, Ethanol)
    Last Post: July 8th, 2009, 10:01 PM
  3. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
