Results 1 to 2 of 2
Thread: Does this afr reading seem acceptable?
    Feb 2004
    Default Does this afr reading seem acceptable?
    Just been wondering if this sounds ok to anyone else. I have a PLX wideband on my 01 C5, the sensor is in one of the rear O2 spots, still stock exhaust. At idle and on the highway both if I have closed loop enabled it seems to like to sit at a reading of 15.0:1. I figured running closed loop and allowing the front O2s to do corrections that it should read around 14.7/8:1, but maybe being post-cats it could read a couple tenths higher? Probably just reading too deep here lol, just wanting to make sure my wideband is accurate.
    01 C5 'vert A4
    EFILive, PLX, & TNT are all we got at the moment.
    Jul 2008
    I would not use that position (post-cats).
    I got an exhaust shop to weld in a bung (pre-cats) for $20.00. You need high exhaust temperatures for an accurate reading. I think tailpipe readings itself has issues, immediately behind cats would most likely give you false readings.
    That is probably why your readings are out of range.
  1. how much knock is acceptable
    By ryans1000 in forum Gen III V8 Specific
    Last Post: November 14th, 2009, 05:46 PM
  2. Oil Temp Acceptable Range
    By bobbycollier in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 20th, 2009, 02:45 PM
  3. Reading an E38 / E67 ECM
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: June 6th, 2007, 07:02 PM
  4. Reading PCM
    By 91LS1S10 in forum Custom Operating Systems
    Last Post: October 21st, 2006, 07:52 AM
  5. reading pcm's
    By ace68 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2005, 02:52 AM
