Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: speed/RPM limit cancel!!
    Apr 2009
    Exclamation speed/RPM limit cancel!!
    Hi ALL,
    I am new to TUNING, my question is I want to cancel the speed limit on my sierra 2500HD 2008 I can't pass the 180 KM/h, and one more thing I've heard that my engine uses 4 cylinders at low speeds then uses the total 8 cylenders on high speeds is there a way to cancel it??
    and finally is Gen IV V8 my engine's name or vortech V8??? thanks a lot
    I know my questions might sound EEzZZ for you guys but i really need your help thanks a lot
    cheers
    You can remove the speed limiter and change AFM activation (or turn it off if you wish) in EFILive.
    You have a Gen IV 6.0L V8 that is a Vortec 6000 (I assume since its a 2500HD its the 6.0L V8 and not the 5.3), its actual RPO code (or what GM calls it) is something different. Use wikipedia to look that up.
    Apr 2009
    thnx mate but how??? in efilive how to do it?? forgive me am tottaly new here thnx a lot
    Aug 2008
    You can keep it from going into 4 cylinder mode by going into EFI Live, look up the table for AFM which is {B0921}and set it to "NO" and for the speed limiter look up table {H0129} and set it at whatever speed you want!!! Be careful and don't go faster than the speed rating of the tires....
    FLASHSCAN V2 & AUTOCAL
    Apr 2009
    thanks alot GAMEOVER!!
    quoting : Be careful and don't go faster than the speed rating of the tires....
    looooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooool
    thanks to every one
    There is a lot of speed limiter methods in the E38.
    If you look in the Speeo section you will find the speed limiter group. The important one is {H0156} Speed Limiter Source, you will need to set that to ECM as well.
    But as the warning in the software states: - ** CAUTION ** Do not set the vehicle speed limiter above the speed rating of the tires fitted to the vehicle.
    What those guys said!
    Cant speak for AFM as neither of my TrailBlazers have it so no idea how to turn it off, bet if I played with it for a few mins I could get it down though.
    Apr 2009
    Hi, thanks alot every one, today was my first time to use the EFILIVE, here are my questions: GMPX u mentioned ;The important one is {H0156} Speed Limiter Source, you will need to set that to ECM as well.
    i went to that one and its written: Other Module, should i write ECM instead??
    ive changed {H0129} to 200 KM/h and left the other parameter as they are 158 KM/h and reflashed my PCM and its the same my car didn;t exceed 158 :( wHYYY!!
    finally I went to {B0921} as GAMEOVER said ; searched for AFM and I found it already set NO,,, and here are the parameters : No
    625.000000
    625.000000
    625.000000
    625.000000
    625.000000
    625.000000
    3000.000000
    3000.000000
    3000.000000
    3000.000000
    3000.000000
    3000.000000
    5.999756
    it is set as NO but it felt like it IS YES!!! plz guys help me out here
    Aug 2008
    Post up your Tune File.....So we can look at it.....
    Apr 2009
    here ...this is the stoke file,,
    thanks a lot
  1. RPM limit
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 7th, 2008, 04:41 PM
  2. comodore 2007 speed limit
    By ALRAJHI in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2008, 06:06 AM
  3. how do i cancel an order
    By goodwrenc92 in forum General
    Last Post: September 4th, 2006, 03:06 PM
  4. HP limit?
    By 80superbu in forum General (Petrol, Gas, Ethanol)
    Last Post: April 1st, 2006, 10:00 AM
