Results 11 to 20 of 27
Thread: speed/RPM limit cancel!!
  1. #11
    Apr 2009
    BTW, GAMEOVER; do u recommend any other alterations to get some +HP from my truck??!?! never forget to mention the temp here raises to 125 F....thanks a lot
  2. #12
    Quote Originally Posted by A.O.A View Post
    GMPX u mentioned ;The important one is {H0156} Speed Limiter Source, you will need to set that to ECM as well.
    i went to that one and its written: Other Module, should i write ECM instead??
    As my original post said, change that parameter to ECM instead or all those other speed limiter values you changed are ignored and the speed limit value is defined by another computer on the car.
    We had a 120F day here over summer, it's pretty nasty that sort of heat, 125F is crazy.
  3. #13
    Apr 2009
    thnx I've done it, but didn't try yet,,, btw if u checked the 1st thread you will find my tuning file,, plz check it for the AFM!! thanks a lot
  4. #14
    Aug 2008
    By the looks of it AFM isn't "ON" and everything is there to adjust the speed limiter....
    Like Ross said change {H0156} to ECM, then you can adjust {H0129} to your desired Speed......
    FLASHSCAN V2 & AUTOCAL
  5. #15
    Apr 2009
    hmmmm,, if it isn;t on ,, why it feels ON??
  6. #16
    Apr 2009
    well!! my truck;s responce is too slow,, u know it takes time while I am crusing and suddnely hit the gas pedal full throttle it takes time to eccelerate !!!! i HATE IT,,I don;t do it for racing but for sudden movemints and maneuver ..thnks again
  7. #17
    Isn't there a message that appears on the instrument cluster when AFM is activated?
  8. #18
    Apr 2009
    yea A WARNING Msg!! says something about the VVT!!!
  9. #19
    VVT = Variable Valve Timing
    AFM is what is used to deactivate 4 cylinders, not VVT. Anyone with with an AFM car that can let A.O.A know what message appears on the cluster when AFM has kicked in.
  10. #20
    New Member Darkanion's Avatar
    May 2009
    I believe what you're describing is part of the Torque Control, not AFM. Try going to {B0532} Throttle Tip-In Torque Reduction, Torque and set it to No. Let us know if that helps the delay you're seeing when you suddenly go full throttle.
    2007 Sierra Denali - Volant CAI, Dual Exhaust, Tuned
  1. RPM limit
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 7th, 2008, 04:41 PM
  2. comodore 2007 speed limit
    By ALRAJHI in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2008, 06:06 AM
  3. how do i cancel an order
    By goodwrenc92 in forum General
    Last Post: September 4th, 2006, 03:06 PM
  4. HP limit?
    By 80superbu in forum General (Petrol, Gas, Ethanol)
    Last Post: April 1st, 2006, 10:00 AM
