Results 1 to 5 of 5
Thread: Virtual ve table
    May 2009
    Default Virtual ve table
    I am having difficulty finding the virtual ve tables. When i try to see the turtorial in my software it says "There is no application associated with the given filename extension" I have tried on a 07 zo6 file and on the 2010 camaro file and nothing. I don't know what i am missing. I have the most recent download V7.5.5 Build (84). I am un sure about the firmware, and updating it as when i try it says" The attached device has previously been upgraded to boot block v2.05.xx or greater"
    The efilive flashscan V2 Programmer can inly be used to program devices with boot block v 2.04.xx or less
    Please use the EFILIVE Explorer" program to program devices with boot block v2.05.xx or greater.
    Did you also install (and update to latest version) EFILive V8.1...?
    You will need EFILive Explorer (EE) from V8.1.
    Quote Originally Posted by Ls1joe View Post
    You need to install Adobe Acrobat Reader in order to view the documentation. IT is available on the EFILive CD, or you can download and install it directly from Adobe's web site here: http://get.adobe.com/reader/
    I highly recommend reading the document: Start->All Programs->EFILive->V8->Documents->Upgrading FlashScan. It will explain what you need to do and how to do it depending on the current state of your FlashScan device.
    Dec 2004
    sorry to state the obvious you have the cable plugged into the laptop ?
    I was about to say that zrx1200, yes you need the V2 plugged in to the USB port before the software starts or the Virtual VE tables will not show up.
    There is also a fantastic tutorial by Simon (aka Swingtan) on the Virtual VE tables here -
    http://download.efilive.com/Tutorial...20Tutorial.pdf
  1. Okay question on the virtual ve table
    By chrleb2 in forum E37, E38 & E67 PFI ECM's
    Last Post: December 21st, 2008, 08:20 AM
  2. Virtual VE table update?
    By Ed@Late Model Speed in forum E37, E38 & E67 PFI ECM's
    Last Post: October 27th, 2008, 05:04 PM
  3. Virtual VE table not showing up
    By XLR8NSS in forum E37, E38 & E67 PFI ECM's
    Last Post: August 25th, 2008, 12:08 PM
  4. E38/E67 ECM Speed Density Virtual VE table
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: May 18th, 2008, 07:51 AM
