Results 1 to 8 of 8
Thread: Questions about the E38 as a Stand Alone
    Apr 2007
    Default Questions about the E38 as a Stand Alone
    Hello everyone,
    I have a question in regards to the E38 as a stand alone controller. I have a 08 Tahoe DOD 5.3L. I tried using the stock cal for dyno use, with all the VATS and such turned of in hopes of it working. Bottom lie is, it wouldn't run. So, I reflash with a Manual Z06 Vette cal that I have running with no issues in a sprint car, and poof, it works.
    So, what I am thinking is for some silly reason it needs to see the trans controller in order to start. Am I way off here or not? If this is the case, is there a bit I can turn off in order to do this correctly?
    I would like to use the stock truck controller due to the fact that I have a stock truck engine. I want to dig into this thing change by change, and using the Z06 box is a bandaid for the situation.
    Any help is always appreciated.
    Best bet in these situations is after you have tried to start it (and it fails) check the DTC's. The ECM will usually tell you what is wrong.
    I think even on an Auto with the TCM missing they will still run.
    I agree with you on sticking with the E38 as the controller, best check what DTC's are getting set and go from there.
    Feb 2006
    The TCM will let the ECM know the vehicle is in park or neutral. A non-communicating TCM can cause a no start.
    I had thought about that, but then not knowing if they are using the ECM controlled starter I didn't want to say anything. I have a feeling the calibration to enable the engine to start without the clutch pressed also works with the P/N switch.
    If they can get the DTC's and something about the P/N switch it there we can sort it out.
    Apr 2007
    SOrry, I should have been more clear. What is happening is I have a starter on the dyno, so it cranks, it has spark, but the injectors are not firing. Not a single click. I will work on it more on Monday.
    On a seperate not, I do like the LIngenfelter converter box. It works flawlessly.
    Dec 2007
    Quote Originally Posted by MSURacing View Post
    Hello everyone,
    My experience with 5.3 cals is that they dont work that well but have started ok whether auto or manual. Have seen some cals that wont start until the second key on attempt.
    Jan 2006
    I have used several of there boxes, much nicer than swapping reluctor wheels out for sure. Did you ever get this sorted out? I ran into the exact same problem with a 6.2 escalade motor as a standalone.
    Apr 2007
    no I haven't yet. How did you fix it? Thanks a bunch in advance
  1. e38 stand alone
    By proflash in forum E37, E38 & E67 PFI ECM's
    Last Post: November 10th, 2009, 03:57 PM
  2. E38 stand alone
    By v8vegaman in forum Gen IV V8 Specific
    Last Post: April 10th, 2009, 07:54 AM
  3. Stand Alone ECM with EFI?
    By Nasty Girl in forum General (Diesel)
    Last Post: December 2nd, 2007, 12:47 PM
  4. Stand Alone Yet?
    By vandykeben in forum FlashScan V2
    Last Post: June 12th, 2007, 03:43 AM
  5. Stand alone flashing V2
    By Bruce Melton in forum FlashScan V2
    Last Post: January 25th, 2007, 03:44 PM
