I have a 0411 computer with OS 01270003 and I'm wondering what alters the timing tables?
Hard to explain but when the car is idling timing is X degrees and when I zip the throttle the timing drops in half. I've looked at all the timing tables and I just cant see what would cause such a drastic drop in timing when there is no knock.
All the tables I see rely on air flow or temp to determine the timing but is there somewhere that uses the TPS too that I'm not finding?
Lee
