Follow the AutoVE tutorial pdf...
You can leave the MAF/IAT connected, since the MAF is failed in in the MAF diag table...
If your IAT was very wrong, then the following may or may not be problems:
- airmass from VE table (g*K/kPa) will be wrong since IAT is blended with ECT... I don't know how wrong...
- spark timing will be modified incorrectly, the timing may affect the actual AFR which means you VE table correction will now be off...
Also take care of these:
See this:
showpost.php?p=87052&postcount=14
Also, B3647 has a bunch of cells containing EQ 1.000 (i.e. stoichiometric AFR)... those cells will cause the COS to operate in semi-open/close loop where it uses STFT's to trim to EQ 1.000... that defeats your AutoVE attempts.
