Results 1 to 2 of 2
Thread: crankshaft correlation
    Default crankshaft correlation
    i keep getting a code saying cam-crank shaft correlation. i put a cam in the truck, is there some kind of a crank relearn i have to do?
    Apr 2008
    yes it is under the dvt seaction in the scan tool
    stock sucks
  1. cam/crank correlation with vortec dist?
    By Aloicious in forum Conversions / Aftermarket Parts
    Last Post: November 15th, 2017, 01:37 PM
  2. IBPW {B4005} {B3701} correlation
    By 5.7ute in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2010, 10:19 AM
  3. LB7/LLY Duramax crankshaft pattern
    By GMPX in forum General (Diesel)
    Last Post: May 27th, 2009, 01:46 PM
  4. MAP/TP Correlation
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: February 10th, 2009, 06:13 PM
  5. Crankshaft Position Sensor Code
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2006, 04:08 PM
