Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 09 LMM tuning problems
    Currently V8 is not a tuner or scanner, it's the foundations though. It is used for Black Box Logging etc.
    Sep 2007
    ok thanks for the info now I feel a little better
    01 CCSB Chevy 4WD HD LB7, built trans, and some other stuff
    Sep 2007
    I took the truck to the dealer today, and reflashed it back to stock, and the mysterious reduced engine power message still shows up with the stock tune in it. This message started appearing after turbo, trans, lift pump, rail pressure shim, bd exhaust manifold, guages, egr delete(valve still in place cooler gone). Now codes are set when the message comes up. Any suggestions on this from anyone, I am still studying it and watching data with the tech 2, but havent seen anything to cause it.
    Sep 2007
    the reduced engine power message was due to K&N filter. But still have the rev limiter issues, and is really annoying. The rev limiter is really holding this truck back from its full potential.
    Jul 2007
    Quote Originally Posted by rgullett83 View Post
    Is there a possibility of V8 for dummies manual? HAHAHAHA but seriously thanks for the update.
    Ha ha... I'm right there with ya...
    Sep 2007
    forgot to update, the reduced engine power message disappeared when the K&N filter was removed and the stock filter was reinstalled. I need to do some work withe the MAF tables I guess
    Jan 2008
    Sounds like it.
  1. Problems tuning the TCM.
    By duramaximizer in forum Diesel
    Last Post: August 13th, 2012, 01:20 PM
  2. problems tuning tcm
    By turk walker in forum Diesel
    Last Post: June 9th, 2010, 08:13 AM
  3. Mafless tuning problems
    By kmidkiff in forum General (Petrol, Gas, Ethanol)
    Last Post: August 20th, 2008, 10:30 AM
  4. problems tuning need help
    By 2000zrocks in forum Gen III V8 Specific
    Last Post: April 30th, 2008, 09:43 AM
  5. LL8 tuning problems.........
    By Rhino79 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: March 18th, 2007, 12:04 PM
