Is there a way to make the scantool remember my previously opened maps?
Sometimes they do remember, other times... THey are all blank.
Anyway to solve this?
Thank you
Thank you
Does this always happen?
I have found that previous maps are lost after:
- opening both the tune.exe and scan.exe at the same time
- editing the calc.pids.txt or sae.eneric.txt improperly
- can be easily avoided
- can be avoided by keeping the scan.exe open while editing the text
after saving it, open another window of the scan.exe and if you get an error
close the newly opened scan.exe window then re-configure the text untill
you don't get an error message.
This will prevent the loss of saved maps under these two conditions.
LC-1 WBO2
1?
I can't have them both open at the same time??? Or do you mean launch them at the same time?
But thanks for the heads up!
Launch (open) them at the same time.
LC-1 WBO2
Create a file called *.mls (in the Maps folder), where * is the same name as the dashboard *.vdb and the same name as the PID selection file *.pid.
Then when you open that *.pid file the matching *.vdb (dash) and matching *.mls (maps) files will be processed.
Here's the layout of the *.mls file:
RegardsCode:; _______________________________________________________________________ ; | | ; | Copyright (c) 1998-2007 | ; | EFILive Limited | ; | http://www.efilive.com | ; | contact: info@efilive.com | ; |_______________________________________________________________________| ; ; This file is used to specify which *.map file should be loaded into the ; scan tool when loading a *.pid file with a name that matches this file. ; ; I.e. if you open a pid file called: "Default Imperial.pid", then create ; a matching "Default Imperial.mls" file in the maps folder. All the map ; filenames listed in that file will be automatically loaded. ; ; The file format is: ; [Maps] ; MapA=filename_of_map_A ; MapB=filename_of_map_B ; MapC=filename_of_map_C ; ect... ; you can include all maps or only as many maps as you want loaded. ; ; Example file:, called "Default Metric.mls": [Maps] MapA={B5913_5914} High_Low Timing Table - Total Spark Advance (MAF).map MapB={B5001} MAF Calibration Table - LC-1 Wideband AFR.map
Schweeettt
I have these files:
VDash/Other_8.vdb
PIDs/Other_8.pid
Maps/Other_8.mls
When I open Other_8.pid I don't seem to get that dash and that set of maps...
Am I allowed to have the "=" sign in map filenames (see attached)...?
I'm not 100% certain, but I remmber having to uncheck something in the Scan Tool . Under 'Edit', 'Properties', 'Startup', uncheck the box marked 'Always load PID file:'.
I think that was it. If not search the forum, I'm sure Paul posted the complete instuctions to get this to work.
It's the 'Always load dashboard file:' that has to be unchecked.
Ok, I will try that... hmmm.... seems vaguely familiar... thanks.
