Results 1 to 4 of 4
Thread: 2007 isuzu cant read pcm
    Apr 2008
    Default 2007 isuzu cant read pcm
    I have been trying to read the pcm on a 2007 Isuzu Ascender and no matter what I do the read wont get past 32k. I have all of the radio and onstar fuses out and the doors are closed. Anyone have any ideas before I go nuts.
    Just one other question, do you know what software version you are using?
    Although I don't think we have made too many changes to the P12 reading or programming process for some time if your software / V2 firmware is quite old it might be worth updating everything.
    To add on, upgrade your V2 (have to have a V2, V1 wont work) to the latest boot block and firmware in V8.1.2 and V7.5.5 build 86 (main page downloads then update them).
    Also, Im assuming you're talking about the 4.2L I6 motor and not the 5.3 correct? Select Atlas I4, I5, I6 PCM for that and E67 for the V8.
  1. hummer H3/isuzu rodeo
    By limited cv8r in forum Lounge
    Last Post: February 6th, 2010, 02:39 PM
  2. 2007 Colorado IL5 PCM Read Issue
    By CGTMS in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: May 12th, 2008, 11:48 AM
  3. Cant read file From 2007 TBSS
    By Jakes4321 in forum E37, E38 & E67 PFI ECM's
    Last Post: September 2nd, 2007, 02:03 PM
  4. EFI Live on an ISUZU
    By Dark Angel in forum General
    Last Post: November 13th, 2006, 04:41 AM
