Page 4 of 4 FirstFirst ... 234
Results 31 to 40 of 40
Thread: BBL triggering Free to air CAL on LC1
  1. #31
    Aug 2007
    No. Only one LC1.
    Whats the solution?
    Quote Originally Posted by Highlander View Post
    Goldigger
    I got a solution for you
    got another LC1 handy?
    I managed to fix BOTH MY LM1s!
    2002 WS6, All-Lunati 383 Strok'r @11:1, Cartek Heads, Keith/Ross Racing Custom Cam, Victor Jr., 492whp 457wtq,
    Cartek Clutch, 9" Moser w/4.11's, 35 spline Detroit Locker, QA1's, NX, BMR, Tuned w/ EFILive V2 Black Box Logging
    Check Out My Latest Tune File: HERE
  2. #32
    Jul 2003
    You are probably going to need another LC1.. If you have another LC1... follow my suggestions above. If you don't keep reading.
    Try to power up the LC1 outside the vehicle or attach a battery charger to the car to keep a constant Voltage... These craps are susceptible to voltage changes...
    Try to see if you can get the program to work/find the LC1... it will take a LOT of tries.. just keep trying till you give up... once you don't and manage to make the program find the LC1... hit reset calibration and all "should" work... do not close the program..Rather update the firmware... if it doesn't work.. KEEP TRYING till it succeeds.
    That is how I have fixed my 2 LM1s and the spare (older one) 3x now...
    There is an issue even with the current firmware where its tripping these innovates...
    aside to that... I do NOT see the serial light flashing. I had made a post earlier about the LM1 not transmitting when it was connected to external power. I believe it was because of the latest firmwares we have all been working with.
  3. #33
    Highlander,
    are you using 2.06.09 or 2.06.10...?
    very interesting methodology... you are persistent...
  4. #34
    Jul 2003
    both!!
  5. #35
    Jul 2003
    it has happened with both... actually.. last night.. trying to revive the LM1 I managed to flash it incorrectly and it went totally dead... at least the screen.. but they still function and/or accept data...
    So... again.. did it.. and after a few tries!!! whew... and this was using windows 7 also
  6. #36
    Member poolshark021's Avatar
    Apr 2006
    Highlander did you leave the key on and open/close the LM programmer until it connected or did you leave the LM programmer open and repeatedly turn the key off/on? I have been trying to connect to my lc-1 from the pc for a while now and no-go. I hope I can get this thing working again so I don't have to send it back to innovate.
  7. #37
    Jul 2003
    pool, i did whatever i could... i powered up and down... i kept the power and tried flashing many times... often times it would find the device and try to flash it... I have to revive an LC1 in these couple of days from this disaster...
    One thing I want to clarify... I reflashed .10 firmware and my serial programming is working correctly...
    One problem I AM having with these LM1s now was trying to program the analog outputs... But.. since I am no longer using them.. Again... I have no issues with them.
  8. #38
    Junior Member Raven's Avatar
    Oct 2006
    I updated my USB to serial driver and I was able to flash the firmware and my LC1 is working again. I'll just have to do the fresh air calibration, I'll do it using DFCO without taking the WO2 sensor off.
    I flashed the LC1 with the 1.10 firmware hope that doesn't give me trouble.
    Nasser
  9. #39
    Feb 2009
    Quote Originally Posted by bmax View Post
    This seems to be why my LC-1 shit the bed too.
    Guys,
    Reconnected my wideband this morning and tried a firmware reflash and it is working again.
    Brad
    99 Firebird Formula, M6, LS6 intake, headers, catback, lid, BRE cam.
    EFI V2, V7.5.5 (Build 149)
    V8.1.2 (Build 142)
    Boot Block 2.07.01 Oct 14, 2010
    Firmware 2.07.05 Jan 29, 2011
    LC-1 with serial cable
    COS 5
  10. #40
    Jul 2007
    I tried today:
    1. Stock PCM and reflash. V2 worked fine. LOL I had forgot how to use it and kept trying an older model vehicle. I'm used to the RR .
    2. Put RR back in and VE tuned. The LC1 and datalogging all seemed to work
    ok. Note, I do not use AD's.
    I'm using V10 of the firmware.
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
  1. Faster Free Rev?
    By Wasted Income in forum Gen III V8 Specific
    Last Post: April 26th, 2010, 01:51 PM
  2. Problem with free air calibration on LC-1
    By MyM8V8 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2010, 09:15 PM
  3. LS1-A stream free?
    By joshp14 in forum FlashScan V2
    Last Post: January 10th, 2010, 08:54 AM
  4. Do your own Free Dyno Chart?
    By ringram in forum Lounge
    Last Post: July 24th, 2006, 08:25 PM
  5. WB free air calibration
    By caver in forum General
    Last Post: July 13th, 2006, 07:04 AM
