Custom Tuning Services
The " math " explanation as read above finds the pw for specific pressure/quantity. The rest is pretty easy...
In a stock calibration there is never a time when main would be commanded alone at 55mpa and 25mm3. Look at the pilots to see that.
Let's see what the help you ask for comes up with.
I'm going to try one more time, just because I'm stubborn.............. My above example is correct if pilot 2 and 3 are active, along with #1. Main US 639, 298 pilot 1, 299 pilot 2, and 299 pilot 3 = 1535. Box says 1531, plenty close enough.
Here's my problem with this though; according to the scan tool pilot 1 is the only one active. 2 and 3 are off during a cruise at 60 mph, never come on. Pilot 1 matches B9101 which is the pulse amount when pilot 2 is NOT going to come on, so that makes sense as #2 is not on. So in this example, if only the main and pilot 1 are on, why do they not add up to 1531? And can someone tell me when and why pilot 2 and 3 are used? I cannot find a single instance where pilot 2 and 3 are on with my truck. I see the tables in the tune, but no idea what makes them active.
You mentioned before that if the scan tool said the pilots were off, then they're off. So how do those two numbers add up to being correct? Or do I have to divide by 10, and multiply by 9, and ..................
Jody
07.5 4X CC 2500HD, EFI Live, MBRP exhaust
new updated website!
Not really running on all cylinders at the moment, I'll try to compile up a reply soon.
04 LB7
2010 LMM
2015 LML
all this pilot talk is a mute point if
"Table B0720 for the LMM's is described as main pulse only"
The table description negates pilot pulse.
Well I guess I lied pilot 3 I never saw active here is a small regen log if you want to see I logged all 3 pilot mm3's and both post mm3's.
04 LB7
2010 LMM
2015 LML
