Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: B0720-fuel pulse
    Jan 2006
    Default B0720-fuel pulse
    ok, I am confused. B0720 is the fuel pulse table. But it doesn't makes sense. In the LMM, compared to LBZ and LLY, this table has values that are entirely too large. Logs do not follow this table either.
    This shows 55 mpa, 800 us, and 25mm^3. Not a valid pulse chart value.
    Has anyone made sense of this?
ID:	5413   Click image for larger version.
    Custom Tuning Services
    Senior Member camcojb's Avatar
    Dec 2007
    My logs show the same. The only numbers that seem to line up are the full mpa and mm3 areas of the map, bottom right hand corner, in other words full throttle stuff.
    Jody
    07.5 4X CC 2500HD, EFI Live, MBRP exhaust
    new updated website!
    Jan 2006
    The LMM table values just don't make sense for a stock table. If I am the first to post this discrepancy, it needs a close look, because this is the basic stuff.
    All other model pulse tables make sense, this one is way out there.
    Or I am missing something, and am about to be embarrassed.
    Mar 2007
    LMM's show total pw then remove that of pilot and multipliers. Looks right to me. Without looking at the rest of the tune that is.
    Jan 2006
    That doesn't make sense either. The log shows 800 us main and 312 us pilot. 1100 total. The total on the table is 1800 after interpolation.
    what multipliers?
    Mar 2007
    Quote Originally Posted by killerbee View Post
    what multipliers?
    I get roughly 1882 ( edited * didn't read picture close enough at first * ) after all the math from just what you have posted. Post the tune so we can investigate further.
    Jan 2006
    any stock LMM tune.
    so i guess I am not getting it. What math?
    Mar 2007
    So post the stock tune you are reporting.
    As far as the math, all the pilots have to be considered. If this is a stock tune and a log of the stock tune..... Then this math would follow and you get exactly 1811.45pw. All this table says is, it takes an 1811.45 pw to get 25.9mm3 fuel at 55mpa All other injection times on and off for each of the injections have to be considered. If say post injection is removed that pw command will not change it will only be added to a different injection pw unless some limiter is set. And so on. Post the tune for further investigation.
    Dec 2007
    Quote Originally Posted by abkimble View Post
    As far as the math, all the pilots have to be considered. If this is a stock tune and a log of the stock tune..... Then this math would follow and you get exactly 1891pw. All this table says is, it takes an 1891 pw to get 25mm3 fuel at 55mpa All other injection times on and off for each of the injections have to be considered. If say post injection is removed that pw command will not change it will only be added to a different injection pw unless some limiter is set. And so on. Post the tune for further investigation.
    I have the same question. Table B0720 for the LMM's is described as main pulse only, no pilots like the LBZ's. On mine there is only pilot 1 at a cruise, say 40-50 mph, no pilot 2 or 3, no post injections. Even if you add the main and pilot 1 it isn't close to what the table shows it should be for the fuel pressure and mm3.
    What "math" are you using?
    Jody
    Mar 2007
    Quote Originally Posted by camcojb View Post
    Jody
    Ok so post your tune also with a log.
  1. throttle pulse
    By lb7blksmk in forum Duramax LB7
    Last Post: November 15th, 2009, 09:49 AM
  2. B0720-FRP: actual or desired?
    Last Post: November 11th, 2009, 05:55 AM
  3. LMM Pulse table
    Last Post: October 30th, 2009, 09:33 AM
  4. B0720 change MPA?
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 1st, 2009, 12:44 PM
  5. Small Pulse Adjust/Low Pulse Width Injector Offset
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: September 4th, 2007, 09:05 AM
