Results 1 to 4 of 4
Thread: PE in HOLDEN VE L98
    Sep 2008
    Default PE in HOLDEN VE L98
    Hi to all ,
    Im new at this and i need help with my PE at WOT.
    I have read so many posts but cant get the answer im looking for. I would like to know what PE all u guys r running on ur car cause i read people run it at 12.5 right across the board some say 12.7-12.9 but what RPM do they command 12.7 and 12.9 etc etc etc... so whats the best power/torque u guys r getting so if anyone can help it would be nice thank u.
    tony
    Jul 2007
    PE mixtures and spark timing are closely linked and both will depend heavily on the engine it's self. The general PE AFR's you have listed are just that, a general starting point. Because every motor behaves differently you will need to tune the settings to values that will suit the car you have. What works for one may not work for another. It may help to run a little richer through peak torque but not everyone does this. It's all part of the tuning process.
    Simon
    Sep 2008
    thanx for ur input Simon
    Tony, I've been convinced from a number of professional tuners and tuning teachers that the power difference between 12.5 AFR and 12.9 AFR is nothing. Running leaner does has other effects, but you aren't going to gain power.
    Have a browse over at - http://www.efi101.com/forum/
    It will be discussed in depth over there I am sure.
  1. Holden E38 Files
    By RonC in forum Gen IV V8 Specific
    Last Post: August 18th, 2022, 06:25 PM
  2. Holden V8 - reluctor 24x with LS1 PCM
    By Batman in forum Conversions / Aftermarket Parts
    Last Post: July 21st, 2009, 05:36 AM
  3. holden VY V6
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2007, 04:38 PM
  4. Holden VE which ECM?
    By ringram in forum Gen IV V8 Specific
    Last Post: March 5th, 2007, 08:39 AM
  5. DTC HOLDEN VS
    By vsboost in forum EFILive V4
    Last Post: October 14th, 2005, 04:24 PM
