Results 1 to 6 of 6
Thread: check out my log
    Sep 2008
    Default check out my log
    a new log to look at4.efi
    Mar 2007
    just my observation but whats wrong with your inj duty cycle? it goes over 300%
    your IATs are pretty high, are you running an IC?
    Sep 2008
    still using the stock injectors(19#) with 12# pulley,just can't get the fuel so i am learning hands on you could say with this testing motor.
    not as of yet but as soon as the new mill is installed, it will be complete including an inter-cooler
    the new mill will be using 38# or 48# injectors,holley stealth ram,383 cubes and much more
    will keep all informed on build and have many ?s on injector set up
    thanks
    Maybe your IFR and VE tables are both incorrect...
    Mar 2007
    just remember don't skimp on the fuel, thats where all the power comes from. All the SC does is give your motor the air needed to burn that extra fuel.
    Sep 2008
    i have not completed a auto ve so the one that i am using is one i built.
    i do belive that it is incorrect but it does seem to keep the truck happy (not knocking hard) for now.
  1. check out my VE
    By nchristian in forum Gen III V8 Specific
    Last Post: June 17th, 2009, 04:01 PM
  2. Check this out
    By mr.prick in forum Lounge
    Last Post: January 26th, 2009, 06:31 AM
  3. Check this out! help!!
    By 05duramonster in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 4th, 2009, 12:39 PM
  4. Please check my tune...
    By kilovictor in forum Gen III V8 Specific
    Last Post: December 11th, 2007, 04:14 PM
