Can I datalog and/or BBL this car w/my dlogger and can I read the bin if its not locked? I've got a V2 FlashScan and 02 Z06. I do have one open license in the V2, but didn't want to use it unless I had to.
07 Silverado DMax Classic
02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
Old Engine: 1/4mile = 9.6/146 New Engine:?
EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
COS5/12212156 For 2002 Z06 Manual Vette
Yes, you can scan/log/bbl and read the bin (which does not use any licenses).
A license is used only if you flash.
There is new V2 BBL software/firmware undergoing beta test... see here:
http://forum.efilive.com/showthread.php?t=10881
You will need to ID the PCM as a E-40.
It will be much more invloved to BBL than use default V2 LS2 pids and Vdash.
IMO,
Bruce
PowrMax Performance
100 mm PowrMAF
thanks Joecar.
Bruce, would you mind elaborating on the BBL difficulty. I had planned to simply run a log on a friend's 2005 and inspect the tuning.
You would have to do this:
- download and install both V7.5 and V8.1 from here: EFILive download software page;
- then carefully read and understand the attached document;
- if you understand the attached document, then upgrade your V2 bootblock/firmware;
- look at this thread from post #210 onward to get an idea how to do BBL: showthread.php?t=9265
V2 BBL is still undergoing beta test (this is a warning) so you may or may not want to wait a bit longer.
PowrMax Performance
100 mm PowrMAF
Bruce is correct about E40... I was showing the process required to arrive at BBL, but in doing so I forgot that E40 pids don't show up.
