I'm working with an 06 CTSV with a 112 Maggie. The car is exhibiting the following problem. In high gear low rpm high load situations such as accelerating away in 5th or 6th gear from 1200 rpms there is what seems to be a misfire. After duplicating this on my dyno what appears to be happening is that there is significant knock and the timing is being retarded. This also corresponds with the transition to positive manifold pressure on the order of 2.0psi. The car came to me with a base flash from Magn which was basically nothing more than scaling for the 60lb hr injectors that are installed. Also, the dealer who sent the car to me had replaced plugs, wires, MAF, MAP sensor so I am assuming that all these components are in good working order. I am happy to provide any additional info anyone would request as this is just an introductory post.
