Results 1 to 4 of 4
Thread: LB7/LLY Duramax crankshaft pattern
    Default LB7/LLY Duramax crankshaft pattern
    Hi All,
    I'm wondering if anybody has any data on the crankshaft pattern produced by the LB7 or LLY engine (not LBZ up).
    In my recent hard disk crash I lost some data that contained this info and of course I need it for something and I can't remember what it was.
    Below is the kind of data we need, it's for the LS1 engine, so either a photo of the Duramax crank itself showing the part that generates the pattern or any data on the pattern itself would be great, some GM training manuals might contain this.
    Thanks,
    Dec 2007
    http://www.dieselpowermag.com/tech/0.../photo_05.html
    theres a photo of the tone ring on the crank
    there is a 1 notch (if i recall) difference between lb7/lly and lbz
    Dec 2007
    http://www.dieselpowermag.com/tech/0.../photo_18.html
    and hears the tone ring for the cam in case you were wondering about it as well
    should give you a idea any ways.
    Thanks for the pics, that looks like it would produce a 58x signal, weird, I thought the LB7/LLY used something very different.
    Edit: You are correct, the ECM pin names show the crank input as 57x
  1. Shift pattern selection
    By PSWired in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 6th, 2012, 11:06 AM
  2. What is Pattern A & Pattern B on the 2010 Camaro 6L80 Tranny Tune??
    By 2010 Bumblebee in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 5th, 2010, 09:06 PM
  3. Engine Brake Pattern for C4500?
    By 577cc in forum Allison 5 & 6 Speed
    Last Post: January 2nd, 2010, 07:02 AM
  4. crankshaft correlation
    Last Post: May 16th, 2009, 03:04 AM
  5. Crankshaft Position Sensor Code
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2006, 04:08 PM
