I have a LC-1 Wideband thats in the process of being installed, slight issue with the heater ground showing a short. I have a good chassis ground have tried 2 other grounds and have tried a different O2 sensor and a 2nd LC-1 unit, still all showing the same 1flash error. I have spoke with Innovate about it and we are trying to fix it.
So far I am not trying to Tune SD. MY car is still on the lift a foot off the ground. I am not going to be trying to dial in the VE with a wideband until I figure out why idle trims are so far off when I have the correct IFR settings for the Injectors I confirmed that I have.
I will be out at the shop shortly with my fuel pressure guage to confirm fuel pressure at the rails.
