Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: loading a new bin??
  1. #21
    You should take some logs to see how your tune is performing:
    VSS
    RPM
    DYNCLYAIR
    DYNAIR
    MAF
    MAP
    LONGFT1
    LONGFT2
    SPARKADV
    KR
    IAT
    ECT
    TFT
    GEAR
    TCCMODE
    TFMPRS
    LASTSHIFT
    On the PIDs tab keep the channel count 24 or less.
  2. #22
    Mar 2009
    thanx joecar i will try and do that as soon as get a bit of time
    04 gmc cc 4x4 6ltr tuned by w4me
    operator error
    efi-live v2 sitting on shelf
    i am to dumb to operate
  3. #23
    Mar 2009
    VSS
    RPM
    DYNCLYAIR
    DYNAIR
    MAF
    MAP
    LONGFT1
    LONGFT2
    SPARKADV
    KR
    IAT
    ECT
    TFT
    GEAR
    TCCMODE
    TFMPRS
    LASTSHIFT
    hey joecar i made a pid list but cant find LASTSHIFT ? also how do i get it on my v2?
    operator error
  4. #24
    Oh, my bad, it is called SHIFTLAST.
    To set that pid list in your V2 you have to run V8.1 Scan&Tune...
    You set the name/controller in the blue section (rightclick->Properties, select controller, change name)...
    then drag pids from the yellow section to the green section, arrange the order of the pids in the yellow section,
    watch the green/blue box bargraph at the bottom of the yellow section, when it turns red you have too many pids/channels.
    then save and program to V2.
  5. #25
    Mar 2009
    thanx joecar i named it after ya
    operator error
  1. Trouble loading pid selection to BB
    By Picto in forum Black Box Logging
    Last Post: November 15th, 2010, 05:00 AM
  2. Loading DSP5 for first time
    By kdawg62 in forum Duramax LB7
    Last Post: May 20th, 2010, 01:49 PM
  3. need help loading tunes
    By tbl in forum General (Diesel)
    Last Post: March 14th, 2010, 09:26 AM
  4. help loading efi live
    By ripmf666 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 9th, 2007, 08:08 PM
