Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: loading a new bin??
    Mar 2009
    Default loading a new bin??
    i just got a tune from jesse and not sure how to dump it to my truck?
    do i hit flash then program pcm? just want to make sure.
    can i save the tune on the v2 or do i need laptop to load it always
    thanx
    04 gmc cc 4x4 6ltr tuned by w4me
    operator error
    efi-live v2 sitting on shelf
    i am to dumb to operate
    Apr 2009
    pretty sure you need laptop regradless ??? load the bin file into tune program and as long as everything is fine (no modifications needed) you can just upload to the pcm
    Mar 2009
    do i do a full flash or just program pcm? also my controller i hit ls1 99-08 ?
    my truck is a 04 6ltr gmc.i got a email tune from wait4me
    i tried program pcm and got a error no data from pcm or something like that
    am i missing something ?
    operator error
    Can you post a screenshot...
    See this support page:
    http://www.efilive.com/index.php?opt...111&Itemid=121
    Mar 2009
    not sure how to post the page?
    operator error
    Sorry, I should have said to send the file to me at paul@efilive.com
    Mar 2009
    sent blx to paul@efilive.com
    operator error
    Mar 2009
    can some tell me the basic way to load a email tune to my truck that i have? i want to make sure i am doing it right and cant find any guides on how to
    thanx
    operator error
    First:
    connect cable to vehicle and start tunetool,
    select your contoller (is it 1999-2008 LS1 PCM...?),
    read the flash (Flash->Read PCM Calibratioon),
    save to file (File->Save tune as),
    turn ign key off for at least 15 seconds,
    Then do the following only if the read was successful:
    copy the email tune file to My Documents\EFILive\V7.5\Bins,
    open the tunetool,
    open that file,
    open as alternate file your stock tune file (File->Load Alternate)... you must have presviously done this,
    compare the two (File->Display Calibration Differences),
    if they can be compared, and if the changes are safe, then proceed,
    turn ign key on and restart tunetool (and open email file),
    do a cal-only flash (Flash->Program PCM Calibrations), it should take less than 30 seconds,
    when flash has finished, turn off ign key off for at least 15 seconds.
  1. Trouble loading pid selection to BB
    By Picto in forum Black Box Logging
    Last Post: November 15th, 2010, 05:00 AM
  2. Loading DSP5 for first time
    By kdawg62 in forum Duramax LB7
    Last Post: May 20th, 2010, 01:49 PM
  3. need help loading tunes
    By tbl in forum General (Diesel)
    Last Post: March 14th, 2010, 09:26 AM
  4. help loading efi live
    By ripmf666 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 9th, 2007, 08:08 PM
