ls2 engine in 98 camaro. 98 camaro wiring hareness. where to begin
1998 Camaro Z28, forged ls2 sts turbo GtsT76, fmic
1999 Firebird, forged ls1 procharger p1sc ls9 cam fmic
1981 El Camino, 5.3 LSX carb, msd 6010
2011 2SS
Not sure what exactly you are asking. Everything will pretty much hook up. You will need the pigtail to hook up cam sensor at front of engine. Knock sensors hook up may be different. That is about it unless tb is etc.
With cam sensor extension/pigtail, watchout that two pins may be reversed (check how extension is wired).
motor is running, i need help with the tune
2011 2SS
You may want to do the AutoVE procedure...
You'll find it here Start->All Programs->EFILive V7.5->Documents->Tutorials on on the www.efilive.com downloads page.
You will need to recalculate yout IFR table using the IFR spreadsheet.
