Thread: can't stop hitting reduced engine power
    Oct 2008
    Default can't stop hitting reduced engine power
    I tried to max out c6101 and it didn't stop the reduced power problem. When i retreve the tdc codes but there aren't any that explain why the reduced power mode is being triggered. All the transmission process enablers are turned off from the factory in the ecm and in the allison program there aren't any process enablers to turn off. I get the feeling the problem lies in the tcm telling the ecm to reduce power. I turned 1514 code off and 1781 off but still the reduced power comes up on the display next to the tach on the dash. There aren't any custom operating systems for the allison control modual yet are their? 604 cu twin turbo gas with allison 5 speed originaly 8.1l with allison 2001 4x4.
    any help would be great
    thanks
    Aug 2004
    Forward your tune to jessebubb@yahoo.com ill look for oddities..
    Oct 2008
    Default here are my tunes
    i also sent tunes to your e-mail, thanks for any help.
    Sep 2007
    I am also having this trouble on an 09 LMM
    01 CCSB Chevy 4WD HD LB7, built trans, and some other stuff
    rgullett83, the engine in this thread is a 8.1L gas motor with an Allison TCM and an LS1 PCM, whatever problem you are having it is not related to what 496chevy is tuning.
    Sep 2007
    oops sorry, I need to pay a little more attention
  1. reduced engine power can't be shut off
    By 496chevy in forum Custom Operating Systems
    Last Post: May 31st, 2009, 01:02 PM
  2. P1514 Reduced Engine Power.
    By Mort in forum Gen III V8 Specific
    Last Post: April 2nd, 2009, 12:51 PM
  3. Reduced engine power
    By redlinepd in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 7th, 2007, 08:30 PM
  4. SD mode = reduced engine power
    Last Post: February 18th, 2006, 12:19 AM
  5. Reduced Engine Power while MAFless
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: December 20th, 2005, 04:08 AM
