If you do, several tests may fail (2, 4, 5, 6), so just ignore this...
If you have done this already, then you will have to:
- reformat the Config/Data spaces,
- copy your *.pmm and Options.txt files to [Config],
- copy your *.dtc files to [Config],
- set date/time,
- set splash screen,
- set the V2 options.
Update: the *.dtc files now go into [Config].
