Results 1 to 10 of 19
Thread: v2.06.10 5/25/09 firmware/Reading
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Default v2.06.10 5/25/09 firmware/Reading
    Is anyone else having any issues with the v2.06.10 firmware from 5/25/09? I can't read my LBZ or LLY, ECMs, I was able to scan my LLY ECM, but not the LBZ, 02-04 4cyl PCM or 06+ Allison TCM. I can pull OS and VIN info from all of them using the V2, but can't pull that info using the tune tool and passthrough. I can pull the VIN and OS info on the Class2 controllers (LLY, 4cyl) though. Any thoughts?
    Jan 2006
    Ok, I downgraded to the "original" 2.06.10, tried to read the LBZ controller, failed, then updated back to the May 25th FW, and now I can read the LBZ ECM, BUT it didn't pull the VIN or calibration number in the read (they both show N/A).
    I notified Paul.
    Oct 2003
    Default How to toggle Metric to Imperial with 2.06.10
    Hi guys,
    Just did the upgrade and now I cannot toggle between metric and imperial units with the enter button. I know this was answered a while back but I cannot seem to find it now. I also have bootblock 2.06.02.
    thanks, Jim
    08 Z06
    Jim,
    Open Scan&Tune, for each pid in the lower left (green) pane do rightclick->properties and fill in "quick select".
    Save and Program.
Name:	pid properties popup - custom.png
    Jan 2006
    Any thoughts Paul?
    Oct 2003
    Thank you Jocar that explains my question. Jim
    08 Z06
    Quote Originally Posted by Cougar281 View Post
    I can reproduce that same behavior here, I am looking at why and figuring out a solution.
    Jan 2006
    Any news? Am I the only one having this issue?
    Let me know if you want any more trace files.
    Still working on it.
    Just to avoid any confusion, I am working on getting the VIN to populate while reading the ECM.
  1. Firmware 2.06.10?
    By samh_08 in forum FlashScan V2
    Last Post: May 27th, 2009, 12:02 PM
  2. Reading an E38 / E67 ECM
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: June 6th, 2007, 07:02 PM
  3. Reading the P12 PCM
    By GMPX in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: March 18th, 2007, 10:48 PM
  4. Firmware For V1?
    By JET LEE in forum FlashScan V1
    Last Post: March 3rd, 2007, 04:56 PM
  5. new firmware help-please!!
    By dynarex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 14th, 2007, 11:22 AM
