Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Current updates - V2 Fails - What Gives?
    Mar 2008
    Default Current updates - V2 Fails - What Gives?
    I just downloaded V8.1.2 Bld55, V7.5.5 Bld87, and V2.06.10 Firmware and now my V2 does not work. Get error $0483. Get failed #4, #5, & #6 when I run self tests.
    Cmon don't you think this is ridiculous. It is 5/25/09 and if there is a bug it should have been removed from the down load materials!!!
    JR
    I need assistance!
    Nov 2006
    LC-1 WBO2
    Mar 2008
    Apparently its now worse - Trying to select PIDS I get "Options.txt not found". I don't use any wide band and now the self test is in a loop and will not complete! Had error $0483 with the first V2.06.10 download! There are no config files down and I can't move any down I get Error $1082 not formatted! This is turning into quite a mess!
    What next?
    JR
    Have you read this (see attached)...?
    You need to copy Options.txt from your PC to your V2 using either EFILive Explorer (EE) or Scan&Tune (S&T).
    What were the bootblock/firmware versions before you updated...?
    Mar 2008
    Joecar -
    Where is that info. never did that before? (with an update) I downloaded off the MAIN website and you might think there would be a note or two about it!
    JR
    HAD:
    V8.1.2 Bld44
    V7.5.5 Bld86
    V2.06.06 FMWR
    V2.06.02 BB
    All worked perfectly and was updated periodically with no problems so what is going on with the new upgrades???
    Now that we are back to complicated updates please give me the steps to get this working again - Thanks
    JR
    Mar 2008
    Jorcar -
    Reformatting and "doing" the config files using the Firmware off the main site the self test FAILS like in my top post!!! SOMETHING IS WRONG WITH THE UPDATE!!!!
    LETS GET IT FIXED SO I / WE CAN GET BACK TO USING THE V2.
    JR
    Mar 2008
    Mr. Prick -
    Your Firmware fails self test #2, 4, 5, 6 not just 4, 5, & 6
    JR
    Nov 2006
    It's working fine for me,
    are you having problems flashing because of this?
    Look in C:\Documents and Settings\All Users\Application Data\EFILive\V8\Config
    for the options.txt, if you don't have it there search you computer for it.
    LC-1 WBO2
    Mar 2008
    Havn't gone that far yet - just doing the update. My Vette is in the trailer ready for next weekends event. Not looking forward to going to the drags and find out V2 doesn't work!!!
    JR
    works fine for me (not helpful, I know). I initially had issues that made no sense, so I un-installed 7 + 8, downloaded the latest 7,8+firmware, installed the lot then it updated the firmware and everything was hunky dory again. I've no idea if there was an error (other than user) eally apparent though.
    Jim
    2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
    All wrapped up in a 2000Lb AC Cobra Replica
  1. E40 system reflash fails?
    By Ls240sx in forum Gen IV V8 Specific
    Last Post: April 17th, 2010, 07:26 PM
  2. Does current BBL software work OK?
    By 02Z06 in forum FlashScan V2 BB Logging
    Last Post: August 15th, 2008, 11:14 AM
  3. V2 current usage?
    By Cougar281 in forum FlashScan V2
    Last Post: February 19th, 2008, 11:05 AM
  4. Logging DMA PIDs on Duramax fails
    By Blacky in forum Diesel
    Last Post: April 28th, 2006, 12:19 AM
  5. Force motor current
    By 87gmc in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 16th, 2005, 01:58 PM
