Results 1 to 9 of 9
Thread: Cannot cruise at 1200 rpm
    Sep 2005
    Default Cannot cruise at 1200 rpm
    This is very frustrating. I have been working on tuning my car for months and I still have one nagging problem. My car will not hold a steady cruise between 1000-1200 rpm. It will accelerate smoothly in that range and it will decel smoothly in that range, but at a steady cruise (like going through a school zone or parking lot), the car will buck and shake.
    Here's what I've done to try to eliminate this problem.
    MAF-less speed density tune.
    Base running airflows correct at various temps.
    IAC Effective area modified to allow Dynamic Air and Idle Air to match from 0-100 IAC counts.
    Spark tables from idle and main tables match at lower rpm levels and loads.
    Increased spark timing (32 degrees) for improved idle and low speed driveability.
    Throttle cracker trimmed.
    OK, here's what I think the problem is: When cruising at 1000-1200 rpm, there seems to be a conflict between the IAC motor and the PCM. I'm sure I'm getting some nasty reversion from my cam at this low rpm level, so that doesn't help either. But at a steady 4-7% TPS, the motor absolutely will not hold steady at this rpm.
    Is there a way to limit the IAC from trying to correct above a certain rpm or vehicle speed? Setting the throttle follower and throttle cracker to 0 does not help.
    FWIW, I am new an EFI Live newbie, but an HP Tuners veteran
    2013 Corvette Grand Sport A6 heads/cam/boost coming
    2009 Pontiac G8 GT
    Vararam, EFI Live tuned, Cruising in 4 cylinder mode, hauling on 8.
    2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE Mods list, Idle Sound Clip, WOT video, 183.092mph video
    2008 GMC Yukon Denali XL 6.2L K&N FIPK, variable valve timing tuned to the max w/EFI Live.
    Nov 2003
    I get the same thing but around 1200 to 1600 with 0% TP. I have tried all the things you have except cracker. I increased the timing (35+) and it helped some but I still have the bucking.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Jan 2005
    You ever find a solution to this Pat?
    I'm not in a state to work on my tuning, but before the tear down I fattened up the AFR in that range and it made a positive difference. I don't recall what AFR I was running but it was in the 13.x range.
    I believe the fundamental problem is the reversion that you are rapidly switching between a lean/rich condition. You can fatten up a bit before you end up in a stoich/pig rich condition, but you will still have the bucking due to the reversion.
    The only real world solution I've found is to put it in first and drive 15mph thru school zone's. It scares the hell out of everybody (straight pipes ) but it's a smooth ride.
    Sep 2003
    Yeah i have the same issue around that rpm also but in 6th drives me nuts LOL
    Larry - HumpinSS
    Jan 2005
    Quote Originally Posted by Dirk Diggler
    Want me to come fix that for you?
    what gears are you running again?
    Sep 2003
    I am running 4.33's
    Larry - HumpinSS
    Jan 2005
    I am running 4.33's
    damn... seems like with that much gear you should be able to ride thru the bucking.
    foff667
    Guest
    sounds like its time to step up to that taller tire & 4.56's lol
    Jan 2005
    I spoke with Pat about this... Said he had to modify the setting for the IAC as it was conflicting with his cruising plans. I'll post my findings on this when I get the bird back online
  1. AFR at cruise?
    By W_D_R in forum Vortec V6/V8 Specific
    Last Post: December 7th, 2009, 06:32 AM
  2. L98/Paxton novi 1200,6psi
    By Harrismarine in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 21st, 2008, 06:04 PM
  3. A/F @ Cruise SD
    By dirt_track_racer_81 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2007, 07:21 AM
  4. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 09:42 PM
  5. Replies: 2
    Last Post: August 11th, 2006, 04:48 PM
