Results 1 to 9 of 9
Thread: New mother board
    Nov 2006
    Default New mother board
    I had to replace the mother board in one of my laptops
    and now it will not boot up.
    It powers up the fan and the HDD but a blank screen is all I see,
    no beeps nothing.
    Is there a procedure when replacing a system board other than just bolting it in?
    Everything in plugged in tight and no extra parts are laying around.
    thanks
    LC-1 WBO2
    Oct 2006
    Normally that is CPU is bad , BIOS will not post and no beeps , check to see if you have maybe inserted it wrong , ZIF (zero insertion force) sockets are fool proof usually or bad Motherboard .
    2006 Trailblazer
    Nov 2006
    Mother board is new and everything transplanted worked before.
    Swithing back to the old board, everything works.
    LC-1 WBO2
    Oct 2006
    Dumb question here , then why are you replacing the Mainboard if it still worked ?
    ESD is a killer , wrist band a must !
    Bad graphics chip ?
    All Mainborads I have done are just plug and play , of course setting things in BIOS (date/time ....etc) .
    Those ribbon cables are tricky some times and can slide into the holder but not make contact , there is usually a couple of tabs on the side that you have to push down to hold the cable in .
    2006 Trailblazer
    Nov 2006
    The AC jack is bad.
    I'm reading some articles about removing some drivers before switching boards.
    LC-1 WBO2
    Oct 2006
    If the Mainboard is a lot different it can pose a problem with drivers , but if it the same type usually not , like a Asus A150 (not real board numbers) replaced with a Asus A150 , no problem but a Asus A150 to a Shuttle C120 then yes .
    Via versus Intel or Nvidia chipset yes for sure or Nvidia to ATI graphics yes .
    Most of the time "post" will still show graphics , just Windows will balk at booting with driver issues or just do restart loops .
    2006 Trailblazer
    Oct 2006
    Quote Originally Posted by mr.prick View Post
    The AC jack is bad
    Ah , replaced several of those , good money in it .
    2006 Trailblazer
    Nov 2006
    Lol
    LC-1 WBO2
    Nov 2006
    I removed the smaller memory chip and now it boots.
    I find this odd because this is a factory part and the slot it was in is the internal one.
    LC-1 WBO2
  1. Holy mother of misfire's
    By Shupe in forum General (Petrol, Gas, Ethanol)
    Last Post: October 24th, 2007, 05:17 AM
  2. newb to the board
    By jlee41 in forum Lounge
    Last Post: February 16th, 2006, 02:42 PM
  3. Dash board
    By 12sec.5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 12th, 2005, 04:47 PM
