Here's me worrying when I see 96 - 97kPa on the scanner.Originally Posted by caver
Bet the view is nice up there though
What view I have to drive at least 300km in any direction to lose altitude.
Se level is 600km away. Its not called the highveld for nothing.
\"You Can Never Have Enough Horsepower\"
I wished I could get 95 Oct. The highest we have around here is 93 Oct and lately 93 is hard to find. So far I have not had to use any gas less than 93.Originally Posted by GMPX
Thanks.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System;
Tinted Windows 35%;EFILive Tune
Keep in mind that the pump octane ratings in the US are an average of research and motor octanes. As a result one brand of 93 may not be as knock resistant as another. We've done quite a bit of dyno testing and found that engines are much less likely to knock with Chevron 93 premium. On several occasions, knock was completely eliminated by nothing more than switching to Chevron. If you haven't yet, try a tankful.
First of all, you gotta watch whatever that guy tells ya! LoL :wink:Originally Posted by GMPX
Have you ever tested my theories? I have recently found some interesting reports from the NACA group to fully support my findings...the best part? The reports were done in 1922! Ha Ha
Just out of curiosity, did you test that on the dyno and come up with that idea? Its just that theoretically, the colder air would be more dense and therefore require LESS timing.......Originally Posted by GMPX
Just a thought.
-Ben
Ben,Originally Posted by EFIGUY
For majority of my day I sit in a nice quiet room (as yet, not padded) tapping away at a keyboard looking at code that makes an LS1 tick....so I am no authority on what works and what does not work in the tuning world, that is why when I talk to people that tune engines for a living I listen and try to learn from what they find.
I am afraid my theory on the extra timing comes from 'tuners' saying that is the sort of timing an LS1 with a mild cam makes best power. Again, I personally have no proof to dispute that.
I did not witness that on the dyno with my car, but then after 7 or 8 runs perhaps the engine could not cope with 28 degrees (it was starting to show slight knock). My test was to run 28 degrees on the street where for the most part you are getting fresh/dense air and the intake is not suffering heat soak, it did not log any knock with that timing, but the seat of the pants dyno isn't real accurate, so was there any gain??, not sure, still left two black strips down the road though
I have seen with my own two eyes the leaner i run the car the more power/mph it seems to run. Previously on a richer mixture i only picked up 25-26 mph from the 1/8 to the 1/4 leaner the car out a tad and it went from 25-26 to a solid 27 mph between the 1/8 asnd the 1/4 with 28* of timing and no knock whatsoever
