Results 1 to 5 of 5
Thread: Calculated PIDs not loading with BBL files
    Jun 2004
    Default Calculated PIDs not loading with BBL files
    No matter what I do, even if I load a PID file with injector DC and another calculated PID using the ACPS for boost I have to manually select those calculated PIDs every time I load a BBL file. If I just start EFIlive the calculated PIDs are selected, but if I load the BBL file they go away and I have to manually select them each time I load a BBL file. Kind of a PITA at times..
    I seem to rememebr the same thing happeneing with V1 BBL and there was a way to keep them selected when loading BBL files, or maybe not..
    After selecting those calc pids and replotting the chart, save the log (overwriting the log file)...
    When you next open that same log file, those calc pids will be present.
    Jun 2004
    I know I can do that, but its kind of a pain when I'm sitting in the car in the staging lanes after a pass with new log files having to select the calculated stuff every time.
    I could have swore I didnt have to do that with the V1 BBL.
    Yes, you are right that if the calc PIDs were selected for V1 then they would stay selected. We need to implement something similar for V2 BBL.
    Thanks for the heads-up.
    Jun 2004
    I thought the calculated stuff loaded with the V1, been a while though so I wasnt 100 % sure.
    Thanks Paul.
  1. How to modify calculated PIds
    By 2000ssnb in forum Tips and tricks
    Last Post: July 4th, 2008, 04:14 AM
  2. Pid Creation / Calculated pids
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: June 26th, 2008, 03:19 AM
