Results 1 to 10 of 12
Thread: will flashscan v2 work on 3.4l grand-am
    Jun 2009
    Default will flashscan v2 work on 3.4l grand-am
    Hello Eric here , new to the forum , recieved my flashscan v2 for my 4.8 sc silverado wow amazing product , is the flashscan v2 able to tune my 2003 3.4l grand-am gt so i can dissable the security system that keeps acting up on us , i tried to connect with the pcm but no luck , does anybody have any info on this subject , thank you
    Nov 2006
    LC-1 WBO2
    Jun 2009
    i know i have been to supported vehicles , couldnt find it , just thought the suported vehicles were not all listed but i think the list is complete , efi live can answer this for me i hope thank you
    Hi Eric,
    You will not be able to tune your 3.4L V6 (RPO LA1).
    You will be able to only scan (you will have to select Dynamic mode).
    Regarding BCM not allowing engine to start:
    - if you make a false start (when you hit the ign key too briefly, motor cranks without starting...), the BCM enters relearn mode which takes 10 minutes (after which the security light will blink)... you have to do this a total of 3 times (i.e. 30 minutes), and then the BCM will allow the engine to start;
    - in future, if the motor does not start on the first hit, turn the ign key all the way to off before trying to hit it again... this will prevent the BCM from entering relearn mode;
    I know, it's a real PITA.
    We've had plans to do the 3.1, 3.4 & 3.8L for sometime, it's on the cards but not as a priority, one day.
    When tuning support is provided, these things would make the car livable:
    - disable security no-start,
    - reduce coolant fan on/off temps,
    - reduce coolant fan AC run-on times,
    - allow TCC to lock in 3rd gear.
    Jun 2009
    so i guess support is not availible yet and yes cant wait to make the car more livable any ideas on when thank you
    Jun 2009
    Eric here and thank you for the info
    Jul 2005
    how do you get to dynamic scan mode?
    Jan 2006
    Quote Originally Posted by Eric View Post
    No you cant tune it with efi. I also have the same car, just sold it today actually. HPT supports it, well they support it but its no where close the same as efi live supporting a car. There are alot of tables missing and many things you cant change.
  1. scanner buttons work work?
    By pullincrazy88 in forum FlashScan V2
    Last Post: May 16th, 2009, 01:12 PM
  2. LC-1 work with flashscan
    By 87gmc in forum General
    Last Post: April 24th, 2005, 02:42 AM
  3. Will EFILive/Flashscan work on my '97 C5?
    By ViciousVette in forum General (Petrol, Gas, Ethanol)
    Last Post: January 26th, 2005, 07:23 AM
  4. Would this WB02 sensor work w/ Flashscan?
    By AllCammedUp in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2004, 10:57 AM
  5. Links to widebands that will work with Flashscan/EFIL please
    By DebianDog in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2004, 04:22 PM
