I have a general question regarding where (throttle%)people think the optimum point to command tip in fueling is?
The setup in question would be an LS2 low compression with a Magnuson 112 HH making 11-12 PSI
I know some like to have WOT fueling happen a little before boost, and some like to see it after you build 1-2 PSI, but I'm wondering what the majority thinks?
Please post up what throttle % you typically like to see WOT fueling happen in an application like this.
Thank you,
Ed
