Results 1 to 5 of 5
Thread: cant pull the stock file
    Banned
    Mar 2009
    Default cant pull the stock file
    When i hook up to the truck i get a pcm locked message. I should be able to pull the stock file off the truck with out a lisense shouldnt i? What am i doin wrong.
    Reading the PCM does not require a license.
    Did you select the correct controller...?
    Banned
    Mar 2009
    as far as i know i did i selected the 98-00 vortec controller. It a 2000 5.3 which one is the corect one?
    What truck is it in? Try 99-09 LS1 PCM and see if that works. Have you checked Try Alternate Keys for the 98-00 Vortec PCM too?
    Aug 2006
    Scarab is right. Select the LS1 controller.
    Jeff
  1. Looking for stock XLR-V bin file!
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: March 21st, 2009, 01:17 PM
  2. looking for a 3.9L stock file!
    Last Post: November 1st, 2007, 06:22 PM
  3. I need a stock file
    By FFP in forum E37, E38 & E67 PFI ECM's
    Last Post: July 23rd, 2007, 06:28 AM
  4. Stock LLY file?
    By Wasted Income in forum Duramax LLY
    Last Post: December 25th, 2005, 04:27 PM
  5. Stock LB7 File?
    By trudynosports in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2005, 06:50 AM
