Revisiting.... Doing some more tests tonight... another LS7... same freaking issue.
C1701 had a little effect on it. but not much. The tests appear to have been shorter. Still. Its annoying.
ROss... PM Sent.
Issue solved... C1709 on latest december 20 release! thank you ROSSSSSS
Boy if only we could control this we could intruduce lean cruise in the e38 tuning.
Cheers Ian
It would be fudged lean cruise, the lean cruise code was gone from the ECM's by the time the E40 hit the streets.
I noticed Commanded AFR is not exactly the same as {B3601} & {B3618}.
The difference is very slight but it's still not what it should be.
LC-1 WBO2
