Results 1 to 10 of 11
Thread: AutoVE BBL...No luck
    Lifetime Member samh_08's Avatar
    Oct 2008
    Default AutoVE BBL...No luck
    Hey guys,
    I have a worn out laptop battery and I can never get a nice long autoVE drive in. I can maybe get in a fifteen minute drive in, but my laptop is dead before I can analyze and tune anything.
    I have tried setting up AutoVE with BBL with no luck. I am using a serial LC-1 and have tried everything I can think of to get all my AutoVE PIDs to show up.
    Please let me know if this is possible, and if so, what I am doing wrong.
    Sam
    Oct 2006
    What pids arent showing up? Post your options txt file so we can have a look at it.
    The Tremor at AIR
    Oct 2008
    Here you go..
    I added in under (LS1 99+|Auto)
    Let me know what you think.
    Oct 2006
    You need to log the MAP pid as well. FWIW I dont log the calc pids as they can be added afterwards when viewing the log.
    The Tremor at AIR
    Oct 2008
    Learn something new everyday. I didnt know you can add them in afterwards.
    So basically I can log everything I want to, then just map and analyze the data with the CALC pids later?
    Also, is there a way to customize what units you want everything to be in. I've tried selecting custom and I cant get what I want..
    Jul 2007
    Quote Originally Posted by samh_08 View Post
    Hey guys,
    Sam
    I know its costly, but if there is a RoadRunner for your car, you may want to consider getting one. There is a small learning curve to using it, but once you get the hang of it, VE tunes happen quick and efficiently.
    Might want to buy a new battery or a few extras. A guy can never have enough tuning tools.
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
    Oct 2006
    Yes, it is a great feature. CALC.PIDS dont actually use any channels so you can still log everything you want with the calc pids. I just find it easier to add them later.
    I am not sure on the customising units. Hopefully Joecar will chime in as he is great with this side of things.
    The Tremor at AIR
    Look at this image, see if it helps...
    When you do this, pressing ENTER on the V2 keypad toggles between metric and custom units for each pid.
Name:	pid properties popup - custom.png
    Oct 2008
    Excellent info! I was expecting to have to do this by code but now its in an easy graphical form.
    Any idea on when the V8 software will be released to the public?
    Thanks Joe,
    Sam
    Jul 2003
    How do you do this???
    on the quick selection i get always NONE...
  1. Replies: 32
    Last Post: June 24th, 2010, 06:21 AM
  2. Searched with no luck, $0183 & $0185
    By 05LLYMaxx in forum FlashScan V2 BB Logging
    Last Post: February 27th, 2010, 07:08 PM
  3. NE1 Having any Luck using RT to update VE Tables With RR?
    By Chalky in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 29th, 2007, 06:04 PM
  4. Replies: 8
    Last Post: January 19th, 2007, 07:29 AM
